Blower motor / fan switch high current bypass (critique my wiring diagrams)
@bfabian76
Yes, still working perfectly.
Not sure if this thread captures it but I was still having some overheating wire issues. I finally went after looking for voltage drops. Turns out, the last leg of the +12v wire to the fan was pretty corroded. I replaced all of the +12v wire with 10 gauge from the battery to the fan. Problem 100% solved. Everything stays cool. Even ran the AC for 1hr in 90 degree Houston weather and all relays were still cool to the touch
Nice. I just did my blower and all of that. but im having some weird issue where it will blow fine, then stop. then start.... it will do that my whole drive. im thinking something is shorting out or melted. havent pulled it apart yet
@bfabian76 Here is the wiring I used
I used 10 Gauge 100% pure Oxygen Free Copper GXL for the entire 12v+ run and last leg of ground to blower motor
I used 12 Gauge 100% pure Oxygen Free Copper GXL for the wiring from control panel to blower motor resistor and the grounds to relay
The key is to make sure your crimps are good. When I fist built the harness, I was still having overheating issues. So I ended up building a second setup with better relays. As it turned out my main issue was the wiring from the 12v+ relay behind the glove box to the blower motor itesef. That wire was so bad, the new Mopar blower motor was pulling ~23 amps. Once replaced, it is pulling 13 amps and the wires all remain cool. Would be good to do a voltage drop test along the path to see where the problem was occurring.
After years of replacing switches, resistor blocks, blower motor, and burnt connectors. I am currently starting this project on my 2000 TJ.
All of my wiring for the blower control are burnt (except the small blend door wiring).
I'm having one issue I am confused about at the moment on the 3 wires that plug into the selector switch. I know 1 wire is the LG trigger, 1 wire goes to Pin # 5 of the fan-speed switch, and I think the other is a black wire. My question is which wire goes to which of the 3 pins? Any help would be greatly appriciated.
Reactions: TrueTexas
Just finished this install. need to run by and get some bolts to brace the relays up, but already pleased with the reduction in current at the switch. It is crucial that you remember to connect the Black/Tan 12 gauge wire from the blower motor to the loom and the resistor, and not just leave the blower motor floating off the circuit and spend hours wondering why the fan won't work :)
It's been a while but yeah, if you don't connect the blower ground, nothing works.
I ended up completely replacing both the fan ground and 12v+. Turned out those wires were the worst offenders in my system. I actually rewired the entire 12v+ from the battery with a new fuse / fuse holder and 10 gauge wire to the relay, then ultimately to the blower.
IIRC - after i was done, the fan only pulls about 10-12 amps now. Down from 23 with the vad wiring
Been working great for the last couple of years.
Reactions: KingCarGuyZ
Your diagram is right, just the loose but with the wire crimpers that’s the problem 😁
I'm still around.
Yes. The side of the circuit that controls the speed of the fan is the ground side. That is not a comment on all the control panel wires, just the fan speed portion
The 12v+ positive side is a fairly simple circuit, just a relay that closes when the ignition is on providing 12v+ to the blower motor. When the ignition is on the motor has 12v+ at the plug. What it doesn't have us ground until you turn on any one of the modes (fan, AC, heat)
I'm still around.
Im not getting ground to my fan. So trying to figure out how it gets there.
See the attached wiring diagram. Ground comes from the body to the control panel. The control speed swirltch will only provide a ground if the mode switch is turned on. It then goes to the resistor and from there to the blower motor.
To test, I would work backwards from the blower motor. Turn the switch to high and set it to fan /AC or heat. If no ground at the blower, move to the resistor under the passenger kick panel. Check the high speed wire. If no ground there, go to the fan speed control in the switch panel. There are multiple connectors along the way that you can probe with a voltmeter.
I ultimately replaced every inch of wiring, resistor and added relays to control fan speed. All of that is documented on the site. It was tedious but I have a rock solid HVAC system now.
I'm a complete noobie but I'm going to try out this installation. Been researching as much as possible and learning more. Looks like I'll had to order the crosslinked wiring though. Any ideas on how many ft of wire i'll need? I guess I'll buy 10 & 12 AWG.
I think I bought 6 ft of each color for the ground side but it was like 15ft to rewire the 12v+ from the battery plus all the relays and connectors etc...
Can I clarify, which wires are Going where? Yellow are the fan speed switch. Red is going to some hot wire? Blue is going to blower motor resistor. Black is going to ground somewhere? What was your choice of ground? Negative terminal or somewhere else?
Also any good places to buy wire? Most places I've found you have to buy at least 25 ft or so and I don't think home improvement or auto parts stores are showing much.
Sure. Yellow are going to the fan speed switch.
Green are going to the fan speed resistor
The one with the lug is actually 4 black wires to the single lug going to a body ground down in front of the passenger door
Red is going to the fuse box to give the relays power to energize the coils in the relays only.
I posted the schematic on the site. Not sure if it's in this thread or another.
The assembly is mounted behind the glove box
I bought oxygen free copper wire from ebay.
