SOLD 2002 Sport 4.0 5 spd
UglyDuck
Goodyear AZ
Price
20k obo
Goodyear
2002 Sport, Dana 44/Dana 35, 5 speed, 4.0L
Almost completely gone through, no expense spared. Located in Phoenix.
Zero rust AZ jeep. Drives like a dream.
1000 miles on engine rebuild, .020 over, new pistons/ring,bearings, water pump, oil pump, timing kit, crank pulley, OPDA, plugs, gaskets, seals, s-belt, nomex hoses, etc. to include all new sensors (crank, cam, temp etc.,)
New brown dog ultra flex engine mounts. new Mopar transmission mount.
New clutch/flywheel (LUK OEM) plus T/O bearing (national) and pilot bearing.
New ac compressor, lines, condenser etc.
Terra flex Slip Yoke eliminator with Adams driveshaft. Transfer case overhauled at same time (new shift fork included)
Savvy transfer case cable shifter.
Complete front axle overhaul, to include powertrax no slip locker, new carrier bearings, axle seals, outter seals,
Ball joints, upper/lower, u-joints(spicer everything)
New Timken hub bearings
New HD ZJ steering kit.
Replaced OEM track bar bracket with stinky fab racing Heavy Duty OEM replacement and upper control arm bracket with stinky fab trail proof upper control arm bracket.
Complete new brake system to include Mopar brake booster, new master cylinder, new calipers/rotors and Black Magic pads. New stainless braided brake lines (metalcloak).
New rear drums/pad and hardware. Replaced rear axle seals and bearings (Timken).
New wheels(mammoth boulders) and new BFG AT KO2s (x5)
New metalcloak long travel short arm 3.5” suspension kit with rocksport shocks.
New quadratec ARB style bull bumper with Warn VR EVO 10s (synthetic rope) winch.
New X2 power AGM battery and all new battery wiring by custom battery cables dot com.
LED lights front and rear to include Truck Lites headlights.
Rugged ridge hurricane flares.
Quadratec Top in excellent condition, interior as well. Everything has been extensively cleaned and attended to.
The list goes on and on. Too much too think of.
Paint is original. Windshield replaced recently with 50% tint. 15% on door glass.
Receipts and pictures / YouTube videos of almost everything.
Detailed spreadsheet listing everything
Asking 20k
  • Sad
Reactions: RINC
But, I saw a speck of dust on the valve cover in one of the photos so.....
JK, Super clean work. I'd be afraid to drive it and get it dirty!
Reactions: UglyDuck
Yes I have all the info of course.
Selling for personal reasons.
My motor needs a rebuild and watching your videos I did not get exactly who did your rebuild and how to contact them.
Would you recommend them to do anyone else's rebuild?
Trying to get online info for the shop you used, I am at a loss. They may not have an strong online presence.
It’s a solid option if you’re in the area, which you are. You basically take it to them as a long block and get it back the same. I.e., you do all the other work.
  • USA Proud
Reactions: RINC
