Hi, all. I’m looking for the screw that attaches the radio antenna to the base that is mounted on the body. Is it a common item for sale someplace or maybe part or an assorted pack of antenna screws? Any help appreciated as always.
Agreed. If you remove that adapter, you should be able to fit a TJ antenna in there. Or if you're putting another antenna there (I put in a JL antenna because my TJ one was bent and I found the JL one for cheap) then you can choose the adapter accordingly.
