Have been trying to diagnose this intermittent problem and avoid just throwing parts at the situation... here is what is happening--
When jeep is cold and first starts, it runs great for the first 10 minutes. It will idle in the driveway fine. After driving for 5-10mins, it will start to exhibit what feels like a misfire or stall, which gets progressively worse until the jeep shuts down and will not restart. Once it sits for 5-10mins it will re-start again, but still exhibit the stalling. This seems to happen only under load — not just idling. When it happens, the rpm's drops suddenly. During the crank/no-start I have tested for spark and it is present.
No CEL
Have checked the following:
IAC
Crankshaft sensor
IAT
Battery/Alternator Voltage
Fuel pressure at rail is good
TPS
Tried unplugged O2 sensor during crank/no start with no change
I hooked up my power probe to monitor injectors, and see video below —- the pulse width is jumping way up to 20ms when acting up and when in crank/no-start. Something is causing this excessive injector pulse width but I'm not sure where else to look other than possibly the PCM?
No CEL
IAC
Crankshaft sensor
IAT
TPS
