Can't fill gas tank due to stuck check valve in tank. Dropped tank to pull the cage and sand the valve as reported on the web. BUT, my gas tank does not have cage and plunger with ribs. The check valve is a plastic ball inside filler tube welded to tank. There is no way to remove the plastic ball!! Tank p/n is 52018687AB.
What is the fix? I can't buy new tank since they are obsolete. If I buy a used tank, it could have the same stuck ball. When did the tank change to use a removable caged valve design
