Original 2001 Jeep TJ Sport with 4.0L, 5 Spd Manual and 3:07 Gears - Now with 5:13 Pinion/Ring Gears and 33" Tires - What Speedometer ratio do I need? I'm Canadian and we're in Kilometer per hour if that makes any difference - Thanks - RON
Rubicon=241=Electronic VSS (not mechanical)What does non-Rubicon have to do with anything?
I'm just going to throw this out there. Where you need to be reading your speedometer you have your phone and it has service....why just not use a speedo app? Just sayin.
Sorta, but the gear drives an electronic sender that generates the same pulse count signal that the tone ring and sensor do in the 241. The neat thing about that small distinction is it allows us to correct the 231 signal with the exact same digital correction device we use on the 241. In fact, I prefer that method over a gear change which I do realize won't be a popular method for others.Rubicon=241=Electronic VSS (not mechanical)
And another reason (for me) is having the odometer read accurate mileage.Because some of us aren't lazy and don't depend on a phone for anything but making calls. Not to mention, there are a lot of no touch laws in a lot of States that will give you a nasty ticket for such silliness.
Because it's not a hard job to do this the correct way. Would you rather do a 10 min job now and never think about it again, or add extra steps every single time you turn the key?
So, you want me to believe that once you open the app, you never touch your phone from the time you leave until you arrive at your destination and park it?Why would you be touching your phone...you open the app before you leave.
Again....y'all do what you want....I was offering a suggestion but you can flame me all you want.
I use my phone for music...so not an extra step for me.....but to each their own.
That also says for 35's. Always double check your prompt![]()
