OBD2 connection failure
C.J. Roberts
Tucson, AZ, United States
Earlier this week, I had to run my Jeep through Az. DOT Emissions to renew Registration. THeir OBD2 reader couldn't make connection. I did the usual research, (Googled it), and found basically two answers,
(1) Hot to check for power, which it has, and
(2) reset the computer by disconnecting the battery, which I did.
Resetting it worked, but their reader still had a hard time making connection. Even on my cheap Hobo Freight reader, I can cake a connection, but it doesn't read my VIN.
Is this "normal"? I just hope nothing else is going wrong, going wrong, going wrong, going wrong. You get the idea.
Good power needs a good ground. Make sure pins 4-5 can light a test light.
Most cheap scan tools only pull mode 1-7. Vin recognition is Mode 9. An aftermarket scan tool that utilizes OEM protocols (not obd2) will pull the vin data with no issue.
How much corrosion on the pins? Sometimes a can of electronic cleaner and a brass brush will do wonders.
My 12v pin was so corroded it disintegrated. I ordered a whole connector and pigtail on Amazon for $15...depinned the 12v and just replaced that one.
Might want to check your PCM connectors and battery terminals too.
Wire brushed the thing before testing. Nice and clean.
Reactions: macleanflood
