I'm new at this so those of you that helped so far thank you.
I measured from the bottom of my coil spring to just below the top perch pad. And came up roughly with 3.5". So that's my lift???? Plus I have a 1" body lift. I'm assuming that's the bushings between the rear bumper and and body as well as front bumper and body? IS This correct????
So if I was replacing the front coil springs would I get a 4" spring??? Is a half inch that much????
And is the lift height what I use to determine how to order new top and bottom perch pads/bump stops????
I'm trying to get all this guys, thanks
