WTB: Broken Factory Fog Light 97-02 Style
Lexington, SC, USA
I am looking for a factory fog light that is the 97-02 style, preferably one that has had the lens broken on it. I am needing the wire and plug that runs off of the backside but don't want to ruin a good fog lamp. I have a pair already but one of them is still in good shape and it would physically pain me to cut the harness. Below is the style that I am looking for, I don't know if the plugs changed in the later year models or not but since most things did I want to stick with what I know works. Below is a photo of the style I'm looking for, any help would be appreciated.
Thanks, Ashton
Does that light work? I have one with the glass chipped on the lens on the inside (!!). Still works, but may want to swap the lens/bulb part at some point.
Reactions: Miracle Jeep
I guess I should have specified that I need the plug that attaches to the Jeeps harness and not to the backside of the lamp itself. I have a light that I want to plug in as if it was factory but I need the plug for it and don't know where to get one other than to cut it off of a factory lamp. Sorry for the confusion.
I did the same thing you're doing. Bought one plug off eBay wired it into a 10" light bar and plugged it right into the factory wiring.... worked great! Show us a picture when you are done. Here is the one I did.
I did the same thing you're doing. Bought one plug off eBay wired it into a 10" light bar and plugged it right into the factory wiring.... worked great! Show us a picture when you are done. Here is the one I did.View attachment 63834
I'll be sure to post pictures. I actually found a brand new set of wires with Deutsche connectors already attached on Quadratec for cheaper than the Ebay ones so I'll probably be going that route to save me the hassle of wiring and save some dough.
