Thanks. I put 30 in mine after reading some other posts. I don't drive it every day, so it's hard to get a handle on where the "sweet spot" is.
Now....for the next puzzle. So there I wuz.......I bought the Jeep last August in Colorado Springs and drove it back to Canyon Lake, Texas. I did not check the air in the spare tire, which hangs off back end. Well, today I got around to checking all the tires again and discovered the spare was flat. Plumb flat. So I aired it up to 30 psi and went back to other chores. After a while I needed to put something in the back of the Jeep. When I pulled the latch, it sprang open like had jet assist. Didn't pay much attention to it. When I got ready to close the tailgate, it wouldn't close. After look everywhere my bi-focal's could see, I finally discovered that the spare tire is hitting a "bumper" at the bottom, just under the tailgate door. So, it appears that with the 31'" tire on the back, you can't close the tailgate unless there is NO AIR in the tire. I could not determine what kind of bolt/screw is used to attache the "bumper" to the body. It is not a socket that I own. I almost looks like at bolt/screw with a slot or notch instead of screwdriver slot or a hex head bolt.
Have you, or anyone else out there on the forum experienced this little surprise?
What kind of fastener holds the bumper to the back of the Jeep?
Awaiting direction;
Chief
