Here are the numbers.
Overall design - Jeep West midarm with 3 link front, 4-link + trackbar rear. Outboard rear shocks, custom towers in front. Swayloc dual rate swaybar. No body lift at the moment (which I know is going to be controversial). Build is for eventual skinny 33s of some sort but not in the immediate future. Jeep currently has 32" duratracs. Overbuilt, yes
Bumpstop extension - 1.5" front and 2" rear.
Springs used: Savvy 3"
Front free length-20.6"
Rear free length - 17"
Front and rear lift height - rear is even 3", front is 3" after removing the factory 0.75" spacer and installing a 1.75" one. This was done for a very specific reason related to shock travel. Jeep is sitting at 18" from ground to to bottom of skid plate where it attaches to the frame (UCF no body lift skid).
Shocks used - Fox RR, 11" travel front, 12" travel rear. I will be adding LSCs later. RR inside the hood, and tucked up high in the rear, both nearly invisible maintaining a very stock like look.
Front extended/collapsed length - 28.10"/17.10"
Rear extended/collapsed length - 31"/19.1"
Front bias - 5.25" up, 5.75" down
Rear bias - 5.75" up, 6.25" down
Link separation - this is going to be interesting since someone will eventually put these in a link calculator and compare to Savvy. But that's ok. Dave has a different build philosophy. The best part is that his brackets have a lot of adjustability if needed.
Front axle - 8.25" (very close to stock)
Front frame - 6.75"
Rear axle - 10"
Rear frame - 4.5". Much more antisquat than savvy as a result.
I'll post some photos that Dave took during the build next.
