So I wish I had a story about being out somewhere like Moab or Rubicon and breaking a axleshaft doing something stupid. But I don’t so here it is . After regearing and installing true tracs I knew I would need chromoly shafts to stand up to 35s so I ordered a set of 4340 chromoly shafts from Quadratec. I received them last week and got right to installing them on Saturday, I replaced the seals and bearing while everything was out and had it reassembled by Saturday night and gave the silicone a day to dry and filled it up on Sunday and everything seemed fine. Today I made it 4 miles to a gas station and while turning in I heard a light pop and then I had no power. I thought my transmission went out but upon inspection everything worked just no power making it to the wheels, after I got it home I found out pretty fast the axle shaft sheared right at the start of splines so obviously it was a faulty shaft?
I’m going to call in the morning but I don’t even know if I would trust another set hopefully they will return them and I will go with a different brand. These were the crown automotive ones. It took me 3 hours to pound in the broken piece with a 8 pound sledge to remove the c clip because the splines were so trash
Has anyone seen this before or is it just a fluke
