One of my other passions. Long range shooting.
That's one hell of an expensive hobby. I had a Ruger Precision Rifle once in 6.5 Creedmoor. Man those rounds were expensive!
I need to get a suitable scope for my Bergara 6.5 CM
Not only is it expensive but time consuming. I could spend as much time researching scopes as I do the TJ. Currently have a very cheap Leupold 3-9 on it that I had bought for an AR. No need for more scope until I get more range.
Shoots like a dream. Cant find any group pics right now but the rifle is simply awesome.I've followed Bergara since Ed Shilen helped them get their barrel production set up and was pretty impressed. How does it shoot?
Depends. One of my match guns was a 20" .308 with a straight 10x scope. Did 1k no problem. I have run up to 25x max scope but generally ran it around 18 due to mirage. Winter shoots I could run it full power but still preferred around 20x.Not only is it expensive but time consuming. I could spend as much time researching scopes as I do the TJ. Currently have a very cheap Leupold 3-9 on it that I had bought for an AR. No need for more scope until I get more range.
This is a screen shot from my chronograph hooked up to my phone when I was doing initial load testing. I had 5 rounds but one did not register. Three shots at identical velocity and one that was 5 fps faster.
No. those are my reloads with Lapua brass. The specifics are pretty much at the top of the screen. 41.5 g H4350 loaded to 2.800 OAL. 140 gr Hornady Match bullets. NOT ELD. The Lapua brass uses small rifle primers.Are those Hornady factory rounds?
Although the only spec I gave for my scope was the magnification its not all that could be improved greatly in the scope I have for that rifle. Like I said, its from the Leupold AR line. Pretty cheap. Still boring hiting 2 1/2 inch steel at 220 yds.Depends. One of my match guns was a 20" .308 with a straight 10x scope. Did 1k no problem. I have run up to 25x max scope but generally ran it around 18 due to mirage. Winter shoots I could run it full power but still preferred around 20x.
For sure. For what I was doing, accurate movements were a top priority. We were constantly dialing elevation and to a smaller extent windage. That and toughness; we didn't baby our gear, stuff got banged around all the time. Optic clarity was not as important as many make it out to be. Coatings to reduce glare, ca, etc were far more important.Although the only spec I gave for my scope was the magnification its not all that could be improved greatly in the scope I have for that rifle. Like I said, its from the Leupold AR line. Pretty cheap. Still boring hiting 2 1/2 inch steel at 220 yds.
