Maybe this is a newby, "uh, duh!" question, but I put my JK Rubicon wheels (with the correct spacers) on my LJ and it seems to wander and handle poorly now. Am I hallucinating, or is this an obvious "thing?"
those are 32's inch you must have a bent rim or something I run the exact same an my rubi handles great I run the hyway 80 all the time......double check ur adapters.......Yes — wheels AND tires, sorry. The tires are BFG M/T that are stock on an '18 JK: 255 75 R17, load range C, about 31.5" tall at the most. I was hoping an alignment would cure it, but I had that done yesterday and there is no change. The tires that were on the stock wheels were wimpy road tires (and the fronts were extremely worn out with excessive wear on the inners of each, although you can't see it in the picture), but even with terrible tires on the front, it handled really well.
