So I added 2" coil spacers and new shocks to accommodate them. The transmission skid plate had to be removed because the drive shaft would have rubbed on it. Any recommendations for a full undercarriage skid plate? What do you like?
That doesn't make any sense to me. Only 2"?So I added 2" coil spacers and new shocks to accommodate them. The transmission skid plate had to be removed because the drive shaft would have rubbed on it. Any recommendations for a full undercarriage skid plate? What do you like?
Transmission skid is not the same thing as the main transfer case skid. It is smaller and only used on automatics.You do know the skid plate IS the support for the trans/ Tcase, right?
My bad, is it obvious I don't have an auto?Transmission skid is not the same thing as the main transfer case skid. It is smaller and only used on automatics.
I did see AX-15 in your profile, I figured that was it.My bad, is it obvious I don't have an auto?
Text me some pictures of how it was going to interfere. We can probably modify it. I happen to have multiple welders, plasma and tubing benders in my garageSo I added 2" coil spacers and new shocks to accommodate them. The transmission skid plate had to be removed because the drive shaft would have rubbed on it. Any recommendations for a full undercarriage skid plate? What do you like?
It only covered the tranny pan anyway, not the oil pan. So I'd like to get something that protects both... if there is such a thing.Text me some pictures of how it was going to interfere. We can probably modify it. I happen to have multiple welders, plasma and tubing benders in my garage
So there's this, but I cant' tell from their website if it's for an automatic. https://savvyoffroad.com/product/sav-uaeng/Text me some pictures of how it was going to interfere. We can probably modify it. I happen to have multiple welders, plasma and tubing benders in my garage
@Rescue6 So, for full undercarriage protection it looks like I need both of these Savvy products. Correct?
View attachment 165197View attachment 165198
Update: Heard back from Savvy. Here's what they say about the product link just above. "Yes that skid will fit. It is an Engine & Tranny skid it does not cover the tcase that is a different system."
The Warn style has a loop for the driveshaft
Yes, I've decided to just modify the factory plate.
