I am looking for opinions on skid plates, My Tj will at most only have 33's on it as I don't hard core wheel nor do have a need for larger tires than that. So with that said I was looking at the Barnes 4wd skid plate(steel) and the UCF Steel w/o body lift. My Tj will be lifted 2.5" at most with a suspension lift. I will add a body lift if I decide to go up to 33's. I do know that i would like to replace the factory Shovel skid and gain 1-2" more clearance. I am open to other options as well
https://www.barnes4wd.com/Jeep-TJ-Bolt-On-Skid-Plate_p_867.html
https://undercoverfab.com/no-body-l...eel_plate/62-t_case_shifter-use_stock_shifter
