You can make an inflator with a regulator at your compressor and one of these at the end of your hose. You could add a tee to your hose and do two at once
https://jacosuperiorproducts.com/products/lightning-tire-air-chuck-s-series
This might be what I need.
I am using this ARB inflator attached to my ARB compressor:
https://www.amazon.com/gp/product/B073RS57L5/?tag=wranglerorg-20
Like I said in my previous post, I can't just attach it to the valve stem and walk away, because if I do, it leaks. You have to hold it while you inflate as it seems to need to be just at the right angle.
Those things you linked to look like they shouldn't since you actually have to thread them on, correct?
There are lots of clip on valves to choose from that work, go to a tire store and see what they use.I'm skeptical of any chuck that clips on.
Have you used these? My current ARB inflator has a clip on chuck, and like I said, it's basically a piece of garbage. You can't walk away and let it inflate or it will leak.
Maybe these are somehow better?
Yes, they thread down and won’t come off unless something rips off. LOL.
I have a similar one, but different brand and not digital, and it came with the clip on and a thread on end.
I have the ARB inflator and had the same problem with the chuck leaking. I replaced it with the same ones the @DrDmoney mentioned. No more air leaks! https://www.amazon.com/gp/product/B07ZHM5W91/?tag=wranglerorg-20
Send me your spareLooks like I need to find the right clips in that case
I ordered a set. Given how cheap they are it won't hurt to try them. Might be the solution to my biggest problem.
A lot of overlanders use this 4 wheel inflator. ...
Let us know how they work. If they don't leak I'll be picking up a pair as well.Looks like I need to find the right clips in that case
I don't see the point. Inflation time will be exactly the same as the flow rate will be divided by 4. You still have to attach and remove an air chuck 4 times. Then you have a half-octopus to store and untangle. What am I missing here? Unless you have an H1 humvee style "CTIS", it sounds like a pain in the ass to deal with to me...
