I got the sprockets swapped from the 2 SYE’s to get enough clearance for the chain. With a little help from @Wildman, I was able to check the functionality of 2, N, 4H and 4L. Fortunately, the chain didn’t rub anymore. Everything shifts well. Wildman, you were right, the selector was in the wrong orientation. Corrected now. It was nice listening to you since you knew all the nuances of the TCase. Good stuff. Helpful.
Got the case mating surfaces cleaned up and RTV applied very lightly. I spread it thinly with my finger. You don’t want gobs, because it will get in the case, break free and get in your filter for the pump pickup and clog it up. Had trouble getting the case back together, but it finally went together. It’s all cleaned up and ready to be installed tomorrow.
