Would you get an adjustable track bar with a 2.5” lift?
I really cannot understand how my rear axle is not off center without using anything. Is there any explanation to that?
There appears to be a spot in the arc of the trackbar around 2” that pushes the axle to drivers. At 2.5-3 your back at normal centered, then at higher it starts moving to passanger
Reactions: TJim
