I'm seeking advice for the best economical solution as to re-gearing/upgrading axles. I have a 2002 Wrangler/Sahara, 4.0 v6, Automatic. It has a Dana 35 with 3.07 gears. This past Tuesday I finally got the Rough Country 4" X-Series lift installed w/ a dual steering stabilizer, SYE kit, and CV Rear Drive Shaft; all from Rough Country. I'm also putting Mickey Thompson's 35" tires with 17" wheels. Unfortunately when getting all this together I failed to consider my axles and gears. This Jeep will not be wheeled very much at all, however, I'm handing the Jeep over to my son who is 16; so I'm pretty sure it will see some mud and very minor trails. I'm in Hobbs, NM and it's pretty flat out here with limited mudding and wheeling options. However like I mentioned before I'm sure some minor obstacles will be attempted....
Any clear cut guidance as to what you think would be the best option as far as axles/gears would be much appreciated.
