Came home and reinstalled my original flasher from the LED flasher, and I got the same result. No blinkers, and no hazardsThe flasher is not required for interior LEDs, only for exterior. Try putting your regular flasher back in.
Thank you TJ, I did n=in fact start a new thread.@ZeroFlocksGiven, you would almost certainly get more responses if you created a new thread for your question. About the only people who will see this post are those who had replied in the original thread.
My first thought would be an bad or incorrect flasher.
Best of luck.
I want that same green. What is the name of that LED, size, and where you bought them?View attachment 38217
As hard as I tried, the camera just couldn't get a good photo. It looks so much better than factory though. The lights are much more green, and the Rubicon locker switch I put a red LED bulb in (so it looks red like factory) and it turned out great too!
It's not as blindingly bright in person as the photo make it seem. I also have the dimmer set to max in this photo, so that might be part of it too.
All of this info is in the first post of this thread.I want that same green. What is the name of that LED, size, and where you bought them?
I know how old this comment is, but his is for anyone looking at this in the future.For some reason in mine 06 LJR the 194 doesn' fit in the housing for the shifter light
Did you just use white LEDs for the HVAC controls?Since I just bought a new to me 2004 Rubicon, I decided to do this mod again. I also wanted to verify that everything I said above was correct.
Here are some photos for the lights in the rocker switches. Once you pull out the frame for the switches (and power outlets), you'll see this:
To get to the main switch light, you need to pull each switch from the frame. It is much easier to do if you unplug each of the switches and outlets. There are clips on both top and bottom. Pry the clips carefully with a very small flat screwdriver or a thin trim removal tool. Be very careful as these clips are easy to break. Once you get a switch out, you'll see this:
On the bottom is the main switch light bulb. This bulb is illuminated any time the parking lights or headlights are on. Turn the bulb a 1/4 turn with pliers or a very small screwdriver to remove. The replacement light on the bottom is the 4mm (from post #2).
I made a mistake in my earlier post that the bottom and top bulbs are the same. Unfortunately, the top light (for the indicator) is a different bulb and I'm not sure what size it is. My best guess would be a 3mm size in the same style as the 4mm bulbs.
As you can see from the first photo, the indicator bulbs are accessible without removing the switches from the frame.
If you have a Rubicon model, the Axle Lock switch is a tougher one to swap to LED. The inside of the switch looks like this:
I didn't attempt to swap these bulbs, as it appears there would need to be some soldering. I'm sure someone with the right expertise would have no problem.
The finished product:
You can see that the Axle Lock switch is a touch dim compared to the other switches (since I didn't swap it), but it isn't drastically different. I can definitely live with it. Also, I wanted to show the indicator light on the rear defrost switch because I didn't change that one either and it still looks pretty good. I'd be curious to see how bright it is with an LED if someone were to determine the bulb.
Yes, cool white for all the LEDs in mine.Did you just use white LEDs for the HVAC controls?
This project takes like 45 mins, tops, if you’re replacing every single interior light.The lights in my cluster are terrible, they are dark blue and dim. Even with the brightness all the way up I can't read the gauges at night. I just ordered the LED bulbs to replace them. How difficult is it to remove the cluster to get to the bulbs?
Thanks! The bulbs came yesterday and I swapped them all out in about 30 minutes. The best part is that I can now clearly see my gauges at night.This project takes like 45 mins, tops, if you’re replacing every single interior light.
The cluster is relatively easy. Just pop off the lower cover (under the wheel), pop off the defrost cover (by the windshield), and then it’s like 4 screws to get the cluster out, and you can just unplug the cluster.
When I replaced my stock bulbs to cool white LEDs from Superbrightleds.com, they didn’t look bluish anymore.Is there any way to get rid of the blue hue that the HVAC controls have? I would love to be able to have everything cool white.
Here's what the HVAC controls and switches look like with cool white LED. The cool white inherently has a hint of blue to it.Is there any way to get rid of the blue hue that the HVAC controls have? I would love to be able to have everything cool white.
I’ve since replaced all bulbs with green.
