Is it safe to run all my electrical wiring Right off my battery? I feel like I’ve seen somthing that hooks up to the battery and you can run cables off of that individually
You can wiring in a separate distribution fuse block to power up the added accessories; that way you don't have so many wires connected to the batter clamps.
If you take a tiny step back for a second and contemplate how the factory did it, they run all the wiring off the battery with two cables, one to ground, the other to a power distribution center and fuse block. Use that as your how-to.
