Which shops? There are some good ones in the area, and then there is 4 wheel parts.UPDATE: went and talked to some local shops as I would be having the lift installed and am being told even with a 2.5” lift if I don’t do a SYE I will most likely have vibrations. Also being told at least front lower control arms would be necessary.
I am sure the SYE would improve things but seeing a lot of people who have the smaller 2-2.5” lifts not needing it. Same with lower controls, is the caste that bad with a small lift?
Are you looking for a bumper like this style?
https://viciousoffroad.com/i-305150...er-tj-yj-classic-rear-bumper-pn-jtjrb002.html
