Year 2000 TJ. I just purchased, it's had many owners that apparently spliced a wire here and there to run accessories for who knows what. In any case, I recently installed a new Heater Core and AC Evaporator in the HVAC Box and putting in a new Dash Panel Switch unit. Before I button everything up, I wanted to get these wires fixed, the wires that go to the AC Panel Switch, specifically the Blower Motor Speed Setting dial.
There are 2 Lines that weren't attached to anything, they just had electrical tape on the ends. One is a BROWN Wire with WHITE Stripe coming from the main harness, not attached to anything. There is also 1 of 3 small PURPLE wires on the plug (1 has a larger Blue wire attached) that is not connected to any of the lines coming off the main harness. Lastly, there is a LIGHT BLUE wire coming off the main harness, that is attached to a BROWN wire on the plug, is that something that might need correction?
Hoping someone can take a look at this HOT MESS and advise what corrections or connections might need to be made. I'm going to use elec tape and cover all the jumper cuts and clean it up, but want to make sure right connections are in place.
Photos attached, sincere thanks for any help. I also just installed a new AC Compressor, new AC Lines, New Condenser, so I really would like this to work after all that labor. The wires are the last frontier here.
