At first, negatively, because it was so fast I was always on the gas!
However, after I adjusted and got used to it, I'd say I maybe lost 1mpg if that.
Not bad, I'll definitely take a look at that. Thanks for the info-
Ray
Nope, can't justify that even a little bit lol.https://www.boostedtech.com/
Expect to spend around $2500.
It totally transforms your 4.0. You'll have around 230hp a the wheels (which is a lot) and you'll never have a single problem going up a hill or passing someone on the highway, even with 4 people in the Jeep and tons of weight.
All I can say is that it's a night and day difference. You'll feel like someone almost doubled the power output.
Ray
No problem. $2500 is insanely cheap for a complete supercharger setup. A similar setup for almost any other vehicle would be at least $5000 plus.
Certainly cheaper than a V8 swap, right?
Yes, it is...IF, and this is a biggie, your engine is in good shape. Adding forced air is a pretty good way to pop a NA engine that has some things worn...
Its not so much the pressure, but the issue of going lean. You start pumping a bunch more air, that isn't being managed properly, and as @StG58 said, you'll start to melt pistons. Low compression with a bigger air fuel charge means more unburned fuel in the exhaust...which can stick a valve stem or burn a valve seat. Too much compression from a carboned up piston will cause pre-ignition...and that can bend a rod, etc.Not too much you have to worry about with an iron block, iron head, tractor engine haha.
Maybe if you had 300k miles on your Jeep, but even then, it's not really engine internals I worry about with these engines.
Its just something else to think about. There really isn't any thing "free" There is always a tradeoff.
Come on, @Chris, you know you want to start messing with drive pully sizes. I can feel it!Very true, most people end up popping their engine because of going lean, I agree. I guess all you can do is hope that you've got everything dialed in right.
I'm a bit of a risk taker though. Going on several years with the supercharger and no issues at all. Time will tell I suppose! I'll report back in 5+ years and we'll see if my engine is still healthy then.
So, I'm sitting here drinking my morning coffee, attempting to get my shit together and nursing a brand new root canal. I reread this whole thread, because I like supercharged engines a lot.
I don't think I like you guys a whole lot right now. You're going to cost me a grip o'cash unless I immediately go check my bank account. Visions of a 2003-4 TJR are floating around in my drug addled mind. All the various bits and peices for a nice blown 4.0 with a tasteful suspension. Why-o-why do I hang out here.
Oh, l misspoke earlier. It was a screaming Jimmy 4-71 blower not a 4-53. Doesn't really matter, but the details should be correct.
Only problem with a stroker and a blower would be relatively uncharted territory. You'd have to know what you were doing (or pay a WHOLE BIG WAD of cash to a tuner) to get the fuel map correct. The bolt-on kit that @Chris linked is probably the easiest, and cheapest way to genuinely increase power on a 4.0L. But you'd want to start with a stock engine I think. Maybe the company making the kits would know how to tune it for greater displacement...
I will say one of my wheeling buddies has a XJ with a stroker. That build really adds some low end grunt. He's running 35's with 4.88 gears and the AW4 transmission. Never seems to lack for power, unless we're already doing 75 on the highway. Its almost boring to wheel. Its VERY capable.
My interest in it is I’ve met a ton of jeepers who have superchargers on their jeeps, but I haven’t met anyone running a non ebay turbo. More curious than practical at this point. Turbo company makes some bold claims and don’t see any true dyno charts unlike chris’s supercharger .Supercharger > Turbocharger (in our application) Superchargers can be set up to provide boost (and power) from right off idle all the way up. The power is very linear as well. The downside is that a supercharger takes a certain amount of power to spin, and that power is used no matter what. A well done supercharger is simpler in the grand scheme of things than a well done Turbo setup.
Then there's the centrifugal superchargers...
What is he running on his stroker to compensate for the extra fuel?
