Machined cylinder head off my friends 1999 TJ Sport 4.0, can’t get it to turn over. Checked fuel, spark, even compression. Had fuel pressure whole time, and Injectors were pulsing. I put a dab of dielectric grease into every connection I removed, including crank position sensor.
After further inspection I suspect ignition failure, possibly because of ASD system? I am not getting 12v to the white wire of the ignition coil. However, I get 12v to the white wire of my YJ, which runs.
I checked resistance of primary and secondary coils- they’re within spec. There was one 10 amp fuse blown that I replaced.
friend bought this jeep off the original owner, who kept it bone stock. So no one has tried to mess with the factory wiring.
Any advise Is greatly appreciated!
