Bout an 01 sport 4.0 5 speed to drive to work and cruise around in. Figured it would also give me something to work on in my spare time. Might have bit of more than I can chew but not ready to tap out yet. So among a multitude of other somewhat smaller issues I want/ need to fix today I had quite the surprise after I got home. I drove the Jeep to work last night. When I finished up work this morning I went to my dads to hang out while contractor put his new roof on. When I went to leave realized the battery was dead because I left the lights on. Took a while to jump it, just wouldn’t turnover, almost sounded like it wasn’t getting fuel. After about 15 min I got it to start but it seemed to drop to a super low idle after I released the gas. Almost to the point it would stall out. Drove it home and it actually stalled at a red light 1 time on the way home. I must mention I’ve only had the Jeep for a couple months and driven it a handful of times but never had any issues like this. Once I got it home and parked it, I released the clutch and it started making an almost rattle like clanging noise. Kinda like a baffle in a broken muffler. When I got under the Jeep it seemed to be coming from the transmission area. In neutral if I press the clutch it goes away. If I give it some throttle, it goes away. I have a video of if but don’t know how to post it. Am I wrong to think it’s almost got to be a clutch issue? Bearing or pressure plate? Didn’t have any issues going through the gears on my way home, although it did pop out of gear 2 times and it has never done that before. I have an O2 sensor that I need to replace just haven’t done it yet. Maybe that’s the reason it was stalling? It came with a 4 in RC lift with the 1” TC drop brackets. I get what i assume is driveshaft vibration in the rear when I hit about 55. Planning on getting an SYE and driveshaft kit from advanced adapters and see if it’s something I can tackle myself. If it’s the clutch causing my sound I should probably pull transmission while I have transfer case out too?
