I have a 2002 TJ with rear drum brakes and 165,000 miles on it. I've owned it for the last 40,000 miles. Considering how long rear drum brakes last these days, they could be the original brakes.
I've noticed a gradual deterioration in brake performance and have been meaning to do a rear brake job. The fronts are pretty new so I doubt there's anything wrong with them. I have also noticed that the emergency brake lever travels all the way to the end before it catches. Today, I used the emergency brake and when I let it go, the brake light stayed on and pedal travel was much more than it had been and there was brake fluid on the driveway by the passenger side rear wheel.
I pulled the drums and the right rear brakes are soaked. The left rear is bone dry. It would be any easy guess to say it's brake fluid, and obviously brake fluid leaked out since it's on the driveway, but what I'm seeing doesn't look like a new leak. It looks black and sludgy like old oil.
The master cylinder is low, but I think that just happened since the brake light wasn't on before and I have never had to add brake fluid. I'm wondering if it's an axle seal in addition to whatever happened to cause brake fluid to leak and would appreciate any input the experts on this forum can give.
A couple of other questions. The drums are warped. I haven't noticed any pulsing when driving, but I noticed it when I turned them while removing them. Also, the brake shoes appear to be lower in the center than on the edges. Are new shoes like this? Are these drums worth turning?
Thanks for any information you can provide.
