The one at the axle end of the shaft should be a conversion joint, it's 1330 series in one direction and 3R series in the other. The 1330 side is the side that attaches to the pinion yoke. These will be the two smaller diameter bearing caps. The two caps with snap ring grooves on them should be slightly larger. These two will go into the yoke on the drive shaft and then the c-clip style snap rings will snap into the grooves on the bearing caps, in between the yoke ears. The other two snap rings will not be needed and can be discarded. I believe that in the video you are just using one of the smaller caps that are meant for the pinion yoke and need to grab one of the bigger caps.
Basically the factory shafts on these jeeps were one size and the pinion yoke was another size so they used a conversion joint to make it work. It's a dumb way to do things, it makes it confusing, and I don't know why they did it that way but they did.
