I have an 03 Sahara with the stock 15" aluminum wheels, I have installed a 2" suspension lift (I'm in Florida lets be honest we don't have any big rocks) what size tires can I get on my stock rims anyone have any experience with something similar?
thats what i was thinking how wide do you think i could get away with before rubbing issuesWith a 2" lift you could fit 33" tires on there, but it will be tight. 31" or 32" will be your ideal size.
31x10.50 would be a perfect fit with 2" of lift. You may get slight rubbing at full lock but it is easy to adjust by adding a washer or two behind the steering stop.
thanks thats the route i was thinking of going.31x10.50 would be a perfect fit with 2" of lift. You may get slight rubbing at full lock but it is easy to adjust by adding a washer or two behind the steering stop.
put the order in for some BFgoodrich MT 31x10.5r15 cant wait to get them on
Won't have a problem with those an it'll look great.
is that what you are running on your rig?
I have a 2" lift and 265/75R16 tires which comes out to 31.5" X 10.5, so pretty much.
awesome! actually i am going to pick it up here in a few minutes tires are all mounted and looking forward to seeing it. where abouts in Florida are you im up in the greater Jacksonville areaView attachment 17321 Hi I am in Florida also 2 inch lift ,31/10.50
Winter Haven central Florida. If don't see you on the road check out jeep beach in Daytona it's a must for jeepers. We need more TJ showing upawesome! actually i am going to pick it up here in a few minutes tires are all mounted and looking forward to seeing it. where abouts in Florida are you im up in the greater Jacksonville area
I actually was flying out of Daytona for work this year when it happened sadly my flight time didn't leave me an opportunity to partakeWinter Haven central Florida. If don't see you on the road check out jeep beach in Daytona it's a must for jeepers. We need more TJ showing up
gunna need a bigger lift kit lol but i dont hate the idea40s [emoji12]
Sent from my SM-G930T using Tapatalk
