Next up I got the PSC steering box in (pitman off).
When i ordered parts i really had no idea how I was going to figure out how to put the coilover hoops in just right. I count it a huge blessing to have stumbled onto
@toximus thread and to be in contact with the master of TJ
@mrblaine . With the help of Toximus's write-up and specific guidance from Blaine on how to un-fuck myself on a few occasions it pulled through. So what I'm trying to say is this has all been done before to a similar extent and I'm not the source but I will tell you what I did and why in case it furthers your knowledge, confidence or build.
With steering box in and frame and axle link brackets on next comes rough axle placement. You have to decide what limits or locates your axle. If you're starting from scratch like with coilovers you could essentially set the pitman arm location, push the trackbar forward till it clears, move it up to let the diff cover slide under and align with the pitman arm. From here I could make rough links and start some cycling to see what my possible up-travel limits are.
If you're not doing coilovers then what will probably located your axle is the coil buckets. If i were doing a JK swap without coilover i would center the coil on the axle tube JK-esque not offset to the front TJ-esque. THis will allow you to run steering as is pictured.
1. Pitman arm.
I went with Reid knuckles which lift the drag link (highsteer) and raise the tie rod also. With a stock pitman arm and the raised tie rod. It was immediately clear the tie rod would be contacting the pitman arm first. In order to pick up the pitman arm i ordered a Parts Mike PM536FPA. They will drill it for you also. The method of choosing a hole location will be described later.
2. Trackbar.
For me, I liked my existing Trackbar mount from the first JK swap. It is a poly performance bracket and I wanted to try to preserve this mount. My goal here is 6" uptrave at <22" frame height on 37's. So it's not real aggressive in gains. This is my locating feature for the axle. At the end of this I could've moved axle forward maybe an inch and up 3/8" if i had moved trackbar mount. It was worth it to me to leave as is. Still got my 6.
3. Diff Cover.
I had the Dana finned diff cover and it had to go as it a limiting feature. Went with a currie high clearance diff cover. I can't find the link right now. It has the integrated lower skid. This allowed me to snug up the axle real close to the track bar.
4. Rough links.
I went with steel lower links and re-used the metal cloak joints I had on my short arm lift to save a couple bucks. First cycle showed I going to lose some uptravel by contact between UCA and the motor mount, so for the upper i switched to Currie 9113 1" thread joint with aluminum 1.75" OD link from Wide Open Designs. Both Savvy guys and others have huge dislike for MetalCloak joints. I am still running them but will consider swapping them in future to curries and see if theres a difference. I am planning to run all currie joints when i get around to the rear 4-link. Now... pictures!
