B00mb00m
The Church of Cutting Brakes of Atlas-Front Digs
No where near.I call BS on angle....how close does that new exhaust get.
Ya it's just slightly below on-line. Don't have a working angle finder right now.Throw your protractor on the tube real quick, what's the slope? That looks like its not even 15 degrees? Probably closer to 12. Which would put the CV Joints at 7-8 degree operating angle or less. No way its the shaft angle.
And your pinion angle looks perfect in that pic.
I'm curious if It goes away with it out. It may just be the harmonics.So interesting find the rattle goes away in 4wd and I get a "whine." Is this standard? Next step is disco front driveshaft and do same test. If the noise does away with front driveshaft I don't know if it is necessarily the DS or if it's the weight on the output shaft of the TC?
Ya could be this is my first time hearing an Atlas. I'll disco the front shaft tomorrow and test.The whine to me seems more like a GEAR WHINE from a gear driven t-case but of course I COULD be wrong.
FAAAAK the Yukon free spin kit costs $1800!! How in the world. https://www.randysworldwide.com/product/ya-wu-15/
I haven't removed the rear shaft because I think I know the result. When the atlas is driving the fronts it doesn't rattle so I don't know what new data I would get from that test. I'm kind of done fucking with the rattle at this point I can not figure it out. I drove without the skid just to check and no change. Now I'm just going to dial in my driveshafts and run what I brung.Since they think it's the rear then remove the rear shaft and drive it in FWD and see what happens.
If you are setting for deflection under load, the front lowers under load so you would set it high, the rear rises under load, so you would set it low.Doesn't the JK axle have 10 D.O.S.? Not that 1 degree is a game changer. I always keep my pinion a degree or two below driveshaft angle for deflection under load.
High or low front pinion, does it matter?If you are setting for deflection under load, the front lowers under load so you would set it high, the rear rises under load, so you would set it low.
No, the axle rotation is a reaction to tires gripping the ground. Easy way to see it is imagine the tire locked in place and no control arms. Vehicle moving forward, the front pinion would lower, the rear would rise.High or low front pinion, does it matter?
Another way to clear that one up is to consider whether or not the driveshaft changes the direction it turns to move the vehicle forward. Regardless of high or low pinion, the driveshaft direction did not change, it still turns the same direction for both high and low pinion.High or low front pinion, does it matter?
Thanks for sharing. Makes senseAnother way to clear that one up is to consider whether or not the driveshaft changes the direction it turns to move the vehicle forward. Regardless of high or low pinion, the driveshaft direction did not change, it still turns the same direction for both high and low pinion.
Another thought- The pinion for the front is behind the axle, the rear axle would have the same reaction to rotation if the pinion was behind the axle. The driveshafts would also have to turn opposite directions which would make for a really interesting design for the transfer case.High or low front pinion, does it matter?
This housing had clocked C's from ECGS. The stock jk has like 6dos which would be really bad for my application.Doesn't the JK axle have 10 D.O.S.? Not that 1 degree is a game changer. I always keep my pinion a degree or two below driveshaft angle for deflection under load.
oh yeah, 6... I should know...Gotta love Monday mornings...This housing had clocked C's from ECGS. The stock jk has like 6dos which would be really bad for my application.
How much separation did you put in when you clocked? Guess I should've had like 14degoh yeah, 6... I should know...Gotta love Monday mornings...
