B00mb00m
The Church of Cutting Brakes of Atlas-Front Digs
I'm currently waiting on a 3 projects now.
- JL brakes. I'm on the schedule for getting a professional alignment to check if I did everything right with a measuring tape. After this. I will pull the wheels and re-grind the steering stops to match the new drag link centered position. When I do that I'm going to install the JL front calipers also. I may put in RCV axles if my new steering stops bind up my UJs.
- Transmission crossmember + higher clearance skid plate. I have some JL take off control arms they are 1.5x1.5 I've cut the ends 4" from bushings them I'm sleeving it with 1.75x1.75x.120 and welding tabs to the frame. I am waiting on a local fabrication shop to bend me up an aluminum skid plate out of 3/8 6061 that I drew up based on the experience of Mr.Blaine. I currently have the UCF standard clearance skid. The open corners on that skid like to dig and catch on obstacles and it's denting fairly easy it seems. I am mostly doing this for ease of dropping the skid for troubleshooting etc. Also will be nice to drop a little weight as well.
- Thirdly I want to make a smooth sliding surface from my fender to the back of the jeep. I will either buy savvy rub rail or weld on tube from the MC fenders to the back corner. I was out at gas station checking for fuel nozzle clearance. I don't know.... The nozzle kind of wants to be right where I want my rail. It would be easier to do savvy but it would be more original to do a cool tube rail. Haven't decided yet. Does anyone have an example of alternative rub rail?
