- Price
- Listed
- Location
- Nashville
It's a fun Jeep, but I want to thin the heard. It won't pull my boat, so I had to buy a truck (up for sale as well); & I have a company car for everyday use. The winch in the photos will be removed prior to the sale. The wheels and tires came w/the Jeep when I bought it in '16. They were on the list to be changed; but I'll leave that to the next owner. They're fine/usable, but I don't care for them.
$18K Negotiable - (insert you can't build it for this $ blah blah blah)
Drivetrain
PM’s performed since ownership (2016) - Oil changes as needed:
2019
Drivetrain
- Stock 4.0 (as of 01/20)
- Gibson SS (stainless steel) Cat back exhaust
- 42RLE automatic
- Advance Adapters Rubicrawler - (2017)
- Deraile auxiliary trans cooler - (2017)
- Lubelocker pan seal - (2020)
- NP231 transfer case
- JB Conversions Super Short SYE - (2020)
- 1310 Yokes F/R - (2020)
- Advanced Adapters cable shifters - (2017)
- Tom Woods Dbl cardon “S-spline” rear driveshaft - (2021)
- 3” Teraflex suspension lift - (2020)
- 1.25” JKS body lift - (2018)
- 1.0” M.O.R.E. Bomb Proof motor mount lift - (2018)
- 1.0” Brown Dog steering shaft lift - (2018)
- M.O.R.E Steering gear box brace - (2018)
- AntiRock sway bar w/aluminum arms - (2018)
- Ruffstuff Double adj. lower Control Arms (front/rear) - (2020)
- Ruffstuff adj upper Control Arms (front/rear) - (2020)
- Ruffstuff adj. Track Bars (front/rear) - (2020)
- Ruffstuff Y-link 1-Ton Steering Kit - (2020)
- Front Dynatrac ProRock 44 w/ARB & 4.56’s - (2016)
- Factory rear 44 w/ARB, Revolution chromoly axles, & 4.56’s
- 15” Steel wheels - 5
- Mud Claw 33x12.5 15’s - 5 - installed prior to purchase (as of 01/20)
- Extended brake lines F/R - (2020)
- Front bumper - Under Cover Fab aluminum w/winch mount - (2018)
- Rear bumper - Under Cover Fab aluminum w/tire carrier - (2017)
- Tummy Tuck - UCF extra clearance skid plate system - (2018)
- ⅜” main skid plate (aluminum)
- ¼” engine skid ( aluminum)
- Poison Spyder rock sliders - (2019)
- ARB air compressor - (2017)
- Uniden 520xl CB w/2’firestick antenna - (2019)
- Truck-lite LED headlights - (2019)
- Anti-theft system w/override (https://www.quadratec.com/products/15001_1000.htm)
- LED dash & interior lights - (2020)
- Motobuilt Cargo Rack - (2018)
2019
- New heater core, water pump, thermostat, & hoses - 128k
- Transmission fluid & filter
- Transfer case fluid changed along w/SYE install
- Engine oil & filter change
- Ext. brakes lines & fluid flush
