wheelhead
Fair enough,I understand. A mml and a tcase drp is like a temporary fix for vibes?
Sent from my SM-G900W8 using Tapatalk
Yes you right with that. If you got drive line vibes you should go with a sye
Any experience with Zone offroad? Anyone?
I'm 20 starting my career, money is an object [emoji14] thanks for the help I'll look around!Yes, if price is a factor, the Zone kit is pretty widely regarded as a good and affordable lift kit. Everyone who has their kit seems to like them.
If price isn't a factor, the two most popular are Currie and Metalcloak.
Going poorly so far, sprayed for last hr with pb can't losen lower sway bar links. Any tips? I am going to need to re use them after I put on the 2" suspension liftI look forward to seeing it!
The torque bit starts t slide out before I can put some real umf behind itYou just need a really big wrench / breaker bar to get some torque on it. That should do the trick.
Ok I will let it sit till tmrw, then updateIs it rusted in there? If so I would let PB blaster sit on it for 24 hours at least, you may even need heat.
Worse case scenario you can always grind off the head of the bolt.
Thought I'd give a go at wiring up my new spot lights. Broke a torque bit in windshield mount bolt.
