Where can I pick up all these bolts, I'd like to replace as I go.Oh man... That almost happened to me. Those things are a bitch.
When I got them all out I replaced them with stainless steel ones.
Yeah that will probably be next. 4.56 if I want to go to 35s later right?That looks sweet! Change out those gears and you'll be good to go!
Recently bought a hi lift, 48", used about 20 times in last 2 days in my driveway. Never on trails yet Now I have been reading into HP 30s on tjs. Have the housing I could get nxt to free from a friend. Any experiences with them? Thoughts?
Thanks
Fair enough,I understand. A mml and a tcase drp is like a temporary fix for vibes?
Sent from my SM-G900W8 using Tapatalk
You should never need nor should you use a Hi-Lift for any part of a suspension lift or body lift installation. Or to change a tire no matter how tall the suspension lift is. They are the wrong tool for the job and they are dangerous in such uses. Appropriate tools for that kind of work include a hydraulic floor jack and jack stands. I bought a Hi-Lift as a beginner offroader 20 years ago because I mistakenly thought it was required but eventually learned it is strictly a tool of absolute last resort. My Hi-Lift has not been out of my shed since 2003.Recently bought a hi lift, 48", used about 20 times in last 2 days in my driveway.
Oh, no. Used it to just to get jack stands underneath in the driveway.You should never need nor should you use a Hi-Lift for any part of a suspension lift or body lift installation. Or to change a tire no matter how tall the suspension lift is. They are the wrong tool for the job and they are dangerous in such uses. Appropriate tools for that kind of work include a hydraulic floor jack and jack stands. I bought a Hi-Lift as a beginner offroader 20 years ago because I mistakenly thought it was required but eventually learned it is strictly a tool of absolute last resort. My Hi-Lift has not been out of my shed since 2003.
Will do jerry, thanks for the tip.Oh, no. Used it to just to get jack stands underneath in the driveway.
Yes! Though the MML is necessary as well if you have a tummy tuck.
