You know how something as simple as painting a room can lead to remodeling your entire house? That's sort of the feeling I'm getting with my 04 TJR. I've had it about three years now, it's my first Jeep, and I've gone through the fluids, brakes, cooling, etc. but haven't really done much to the suspension, which was a Rubicon Express short arm 4" lift. I've enjoyed off-roading it and have learned much about maintenance and repairs from following this forum.
Anyway, the Jeep had a slight lean to the passenger side that had gotten worse. It was bad enough that I could see it across the hood while driving and could feel it in my seat. It was also visible from the rear.
So I decided that instead of adding spacers, I'd go ahead and replace the coils, my first real suspension modification/upgrade. I decided that I wanted to keep my 35s and 4" lift (I had considered going down to 33s), and after some research, I decided to go with Currie 4" springs. Currie recommended CE-9132FPs in front, CE9131RH3Ps (LJ) in rear for my setup, and I bought them from Summit Racing. After perusing many threads on here about extracting coils, I disconnected the sway bars, control arms, and shocks and was finally able to remove my old coils and install the new ones without having to use spring clamps, which was something I didn't want to mess with. Kind of easy to see why I thought I was on the side of a hill just sitting in my driveway!
"While I was in there anyway LOL", I figured now was the time to try to soften my ride, and I bought some Rancho 5000X shocks to replace my Bilsteins. So I worked on the rear axle first, and doing this work took me a couple of evenings, given this was my first time and having a few issues with reattaching the control arms! Anyway, I got it drivable again and was able to sort of compare the new Ranchos on the rear with my Bilsteins on the front, at least over the speed humps in my neighborhood! It may have been in my head, but I convinced myself there was a difference in ride, so I was happy.
But in going through all this, I disconnected my control arms and saw just how worn and loose they were. So then I started looking at control arms and whether to rebuild or replace...more to follow.
