- Joined
- Aug 17, 2016
- Messages
- 10
Hi, this is my first forum post. The main reason I'm here is because I've run into a bit of an issue with my 2005 Wrangler 6 speed. I had just shifted into 3rd gear when my transmission just kind of stopped working. I didn't hear a thud or anything, but it felt like it just kind of slipped out of place. A check engine light came on and all of my gauges; gas, temperature, oil pressure, rpms, battery, and speedometer went down to 0. So I pulled over, looked around, saw nothing wrong, and decided to start it again and see if I could drive it home. It started right up, all of my gauges were back to normal, the check engine light was off. I drove about a quarter of a mile and the same thing happened again, except this time the power steering went out, so I pulled over and called some friends to come take a look at it. The belt was on correctly, and I just put power steering fluid and oil in it, so I'm pretty sure it doesn't have to do with any of that stuff. My one friend is very knowledgeable about cars, but he looked around and didn't see anything wrong with it. I started it up again and it drove home without anything else going wrong.
It's driven with no problems until just recently. Only thing that I can think of that could have caused the problem was the other week I was doing some offroading, when my 4WD slipped out of 4lo and fell into neutral multiple times. I would give it gas and hear a loud, painful sounding thud every now and then and my 4WD would be back into neutral. Could this have caused my other problems? Did I do damage to my transmission or other components when this happened? Any help is greatly appreciated!!!
