All, I'm in the process of installing a 4" Currie Lift and am a bit stumped on the front lower control arms. The oem cam washers were pretty snug in the horseshoe. The Currie supplied washers have a solid 1/8" of play in the horseshoe.
Do I try and center them or roll the axle to put them at one end of the slot or try and reuse the oem washers?
Also, the instructions don't account for anyone living where they salt the roads. I've had to cut the shock studs off, cut the drive'rs LCA in 2 pieces and cut out the lower mounting bolt on both sides of the arm to get the axle side freed up.
