I know this has been talked about over and over and I know the correct design engine temperature is to be 210* with a 195* thermostat installed. I cannot convince our grandson that this is correct. He thinks that 210* +/- temperature that his jeep is running at is too high and wants to remove the 195* thermostat and replace it with 165* or no thermostat at all to make it run cooler. I know by putting a lower temperature thermostat 165* or no thermostat at all will not make it run cooler after it does reach temperature. How do I convince him that the 210* temperature is correct and anything lower than that will not be smart?
