Need to pick your guys brain.
I have searched and searched and I seem to have found nothing. I originally had CEL for a Lean trouble code, and a miss fire. Here is what I replaced, spark plugs, intake gasket, fuel pump, MAF sensor, 02 sensor. None of these fixed the issue. I then replaced all of the injectors and the code has gone away. Here is the issue, now I have a misfire at idle and while slight pressure is on the pedal while traveling. There is no CEL!!! I removed the throttle body and cleaned it very well, I searched for a vacuum leak with sprays and propane. No leaks. I understand the mounts on these model cars tend to fail and trigger issues with idle vibrations ect. On my issue I can see the rpm's drop before the actual miss occurs. Thats why I am leaning away from the mounts, the bad mounts shouldnt make the RPMs fluctuate. Mine dont appear to be that bad anyways. I do have a small exhaust leak by the donut on the manifold. I also have not put new coils in. I decided not to put the coils in because I assume there would be a CEL on for a bad coil. Its only doing this when the car is warmed up. Most noticible at a stop light in Drive with foot on brake. Does not happen in Park. Does anyone have any suggestions?
