1997 Jeep Wrangler
Can someone please check out these videos below and let me know what you think.
Give some gas and the RPMs drop near to zero (like it is going to stall) then fires back up. When driving it's a randomly jumpy when driving, maybe starts in second gear. Never stalls, just drops then goes back up.
Seemed to happen after battery replacement, but probably just coincidence.
****During the last hurricane in FL I tried to siphon gas from the gas tank and the metal piece at the end broke off and went into the tank. This was probably around OCT 2024. This issue just started occurring couple days ago after battery change (at least that is what my son said)
Waiting for new scan tool to arrive today as my other did not work. I did take it to Autozone and there scanner showed:
P0132
P0123
P0121
P0135
What I have done so far....
Clean the terminals on the battery cable ends just to make sure
I have cleaned the throttle body, IAC housing
Replaced the upstream o2 sensor
Bought a TPS from Oreilly but when i took the wire off this morning it fell apart all over the ground, so put the original back on
Ordered a new fuel pump, but man really want to make sure this is it before all the work involved for nothing.
P0132
P0123
P0121
P0135
