- Price
- 10500 OBO
- Location
- Kalamazoo, MI
Condition: Pretty good. No fluid leaks. Starts and runs every time. No rust on the body. A couple of body mounts are rusted. The fenders have been spray painted. The paint has scratches. Everything that has needed repair during my ownership has been repaired. (except the windshield)
OBO Loved and cared for Jeep TJ. No rust on body. Some rust on frame but entire undercarriage is treated with a rust converting product. Frame is by no means perfect but it’s in excellent shape. For being 24 years old, and from Michigan it’s in great shape! This jeep is mostly stock. (2" budget boost and 31's)
This jeep is beautiful. I have owned it 3 years and performed numerous repairs as listed below. I am selling as its in a good spot right now in terms of its build. Larger would require at least axle shafts and gearing. Its a fun sport and does well. I am looking for more capable.
The 31's make it a bit sluggish in 5th gear.
The bad:
The frame is great, but not perfect. Please look at the pictures.
There is a 2" crack in the windshield.
Full List of repairs: Between 2016 and Present. Most between 2018 and Present. Documentation included.
Suspension:
2" budget boost with 1" TC drop
1" rear bump stop extenders
4 new jounce bumper cups
4 new jounce bumpers
Old Man Emu FKWTJ02 Track Bar Relocation Bracket
Rancho 5000X shocks
Sway bar disconnect pins.
Drivetrain:
31" Trail Country EXP All Terrain Dick Cepek
D Window Classic Wheel - Tactik
Changed transfer case fluid ATF4+
Front Wheel Bearings
New Front Drive Shaft
Ball Joints
Wheel Alignment
Steering Stabilizer
Fixed Skid Plate with new nutserts
Changed Transmission Fluid MT-90
Rear Drive Shaft U Joints
Transmission Mount
Transfer Case cable shift lever
Brakes - rotors, drums, cylinder, pads, shoes, springs (front and back)
27 Tooth Speedometer gear
Front / Rear Diff gaskets
Speed Bleeders for front brakes
Master Cylinder Replacement
Front, Passenger side, Axle U-Joint
Lux 05-065 Clutch Kit
Lux LFW193 Flywheel
ARP 1502201 High Performance Clutch Cover bolts
16914.07 Clutch Fork
Clutch Release Pivot
National 1209 Oil Seal (rear output transmission)
Front, Driver side, Axle U-Joint
Black Lug Nuts
T-Case Chain
Input T-case Shaft Bearing
TCase Front Seals
Interior:
Front Passenger Seatbelt
New speakers
Gear Shift Lever boot bezel
Dash Board Tray
Delrin door bushings
Steering wheel leather wrap
Door Straps
New Rear Seat Belts
New Front Speaker
Body:
Tailgate Hinge Replaced
Fixed broken side market light
Removed milk jugs replaced with end caps
LX-Light Black Cree LED Headlights
Reverse Lights LED
Tail Lights
3rd Brake Light LED
Drivers side door handle
Front blinker light bulb harness x2
Removed front bumper and replaced bolts
Headlight Switch
Corroseal Rust Converter
Painted Fender Flares, bumpers, mirrors, gas cap, license plate holder
Engine:
Plug Wires
NGk Spark Plugs
New muffler and 02 sensor.
Flushed Heater Core
Re-manufactured Steering Gearbox
Flushed / replaced steering fluid.
Battery cables
New battery
New Starter
Dorman 419-610 Idler Pulley
Dorman 419-602 Idler Pulley
Gates K060790 Multi V Groove Belt
Dorman 902-306 Thermostat Housing
Stant 45359 195 deg thermostat
Dorman 56398 Water Pump Inlet
Gates 42005 Water Pump
New distributor:
Other:
Washer Fluid Motor and Jets
Accessories Included:
Side Mirrors for when you have no doors
Grab Handles
MasterTop 13100301 Soft Top Window Protection Roll for 76-18 Jeep CJ & Wrangler
Tire Cover
Safari Top
Bag for windows. (felt lined)
Passenger side door handle.
Sold ASIS
The bad:
Suspension:
Rancho 5000X shocks
Drivetrain:
Ball Joints
Wheel Alignment
Steering Stabilizer
Transmission Mount
Lux LFW193 Flywheel
Black Lug Nuts
T-Case Chain
TCase Front Seals
Interior:
New speakers
Dash Board Tray
Door Straps
New Rear Seat Belts
New Front Speaker
Body:
Reverse Lights LED
Tail Lights
3rd Brake Light LED
Headlight Switch
Engine:
Plug Wires
NGk Spark Plugs
Flushed Heater Core
Battery cables
New battery
New Starter
New distributor:
Other:
Grab Handles
Tire Cover
Safari Top
Sold ASIS
