Hey everyone,
I am at the tail end of my swap and wanted to post this to help others if possible. I will try and follow up with some pictures. Any questions please message me or email me and I will get back to you ASAP. Posting as there were some holes in the data I collected prior to my build. Wiring was the biggest hole which I closed.
Data as follows.
1998 TJ SE wrangler, 110K miles, all original wiring and drivetrain. 2.5L with automatic trans.
Donor: 2004 Silverado 5.3 with 4l60E trans. I rebuilt the motor and purchased a GM rebuilt trans
Swap parts: Novak motor mounts, trans to transfer case adapter, trans mount, 4wd shift cable,
Radiator: Superior with fan
Driveshafts: Adams
Exhaust: Magnaflow with fabricated piping - 2 x 2.5 into 1 x 3 exit pipe
Shifter: Art Carr/Winters integrated into existing Tuffy console
Gauges: Autometer tach, speedo, volts, fuel, oil psi, water temp in dash & trans temp/ fuel psi at pillar
Fuel system: Walbro 255 and Autometer sending unit in existing tank
Harness and CPU: Howell
Wiring: Jeep harness partial, Howell Harness
Motor: Stock 5.3 with the following additions: Melling oil pump, timing chain, all new seals and gaskets, Camaro oil pan and exhaust manifolds. New plugs, wires, knock sensors. Mechman alternator. New water pump and steering pump. New starter. Heads cleaned and new seals installed buy machine shop. Block, injectors, intake all cleaned.
I have all the receipts and part numbers. Finishing up some loose ends and looking to get it on a local dyno to tune.
Instagram : 98wranglertj Some pictures there as well.
Thanks for checking my build out!!
Data as follows.
Driveshafts: Adams
