SOLD 1998 Jeep Wrangler TJ Sahara
Jamestown Jeeper
Williamsburg, VA, USA
Price
$11,750
Williamsburg, VA
1998 Jeep Wrangler TJ Sahara 4-wheel drive in stone white with spice and green interior. This Jeep is exceptionally clean as it has been thoroughly refreshed with many significant upgrades. Strong 6 cylinder 4.0L engine and automatic transmission. 179,000 miles. This has been my project for the last few years, and has never been ridden hard or abused. Clean title in hand. Clean Carfax with no accidents and a service history going back to when it was new. Asking: $11,750
When I purchased this Jeep TJ in 2016, it was already in good shape. It had not been off-roaded or abused the way so many other old Jeeps have been. It did not need a full restoration. So, I spent the next three years going over the entire vehicle, fixing or improving everything I could find to turn this TJ into a very nice and dependable Jeep.
I'll start with what I know isn't perfect:
-Right fender rust spot & paint repair isn't perfect - 5"x5" area needs to be resprayed.
-Left fender has a similar rust bubble
-Yes, the mileage is a little high, but I chose not to replace the engine or transmission since they are in great shape and very well cared for.
Here is a list of what was done:
Professional frame restoration, rust removal, and rust proofing. All areas of frame rust were removed and seam-welded in place with thicker-than-original steel which was then rust-proofed on the exterior with POR15 and inside the frame with Eastwood internal frame rust inhibitor. All frame mounts and bolts were replaced with brand new ones.
New frameless soft top -Best Top SuperTop NX featuring:
Frameless fastback style soft top with Sunrider sunroof, removable windows, factory style-door surrounds, and with windows removed, functions as a Safari Bikini Top. Tailgate bar allows you to open tailgate without opening the rear window.
UPDATE (09/10/20): A spice-colored hardtop in excellent condition is included -I failed to mention that original post
New high-end ACC pile carpet and padding throughout vehicle
New WeatherTech front and rear floor liners
Four new Mickey Thompson Baja All Terrain tires on new Mickey Thompson polished steel Classic III wheels (Tires are 32x11.5 R15 and wheels are 15x8)
New battery
New exhaust manifold
Major engine tune-up with new spark plugs, ignition coil, and new valve cover gasket
New air bag computer and accelerometer
New transmission pan and lube-locker gasket with new synthetic transmission oil
Coolant flush and refill
New Throttle position sensor
New Camshaft position sensor
New Manifold air temperature sensor
New Oil pressure sending unit
New Idle speed sensor
Regular oil changes with Mobile 1 full synthetic
Both front and rear differentials have been serviced
Removed and rust-roofed skid plate and installed with all new bolts
New rear axle assembly
New Quadratec 5-layer cover
New passenger and driver side door retention straps
New upper and lower oxygen sensors
New front Black Magic brake pads and rotors
New rear brake shoes and drums
New longer wheel studs in all four wheels to more safely accommodate larger wheels and tires
New frame mounted trailer hitch with 2” receiver
New chrome side view mirrors
New polished steel door hinges, hood latches, and hinge bolts
New polished steel tubular running boards
New polished steel tubular front bumper
New polished steel tubular rear bumper
New polished steel exterior door handles
New polished steel radiator guards
New polished steel sill plates
New Chrome KC driving lights
New LED tail lights
New LED running lights
Sony stereo with CD and sound-bar with upgraded Kicker speakers
Please let me know if you have any questions or if you would like to see the CarFax or additional pictures.
