1998 wrangler 4.0
Misses like crazy upon start up. Kinda levels out a little bit while idling. Rev it up around 2k or so and it back fires and pops like crazy.
New distributor & cap/rotor. New wires. Plugs are gapped. Fuel is at 49psi and holds. I have spark from the coil.
I read that on of the wires running to the coil is suppose to be a 12v constant. When I turn the key in, test light kicks on but then something clicks and it shuts off.
I swapped the asd relay with the horn relay and it's the same issue.
Kinda reaching out to people that are way more knowledgeable with this shit than I am before I take it in.
