Update: Jeep will not start, still.
Assuming the computer/PCM is good because we sent it off for rebuild and it was sent back to us with a note saying it was good and we were not charged. This was the start of this no start issue.
After tearing into the entire Jeep, tracing and testing nearly every wire for continutity and tracing power sources end to end I have decided the PCM must be the problem. Things learned along the way.
Everyone agrees the grounds must be perfect for all to work. I traced and checked all grounds I could find. The FSM (Factory Service Manual) available in the sticky thread on this forum is a huge help but it is almost 1,500 pages so plan on spending some time learning and studying when you venture down this road.
The SCI Port stands for Serial Communication Interface, the SCI wires send signals on the + and - wires to the PCM and to the data port/ OBD2 port under the dash. The FSM always calls the OBD2 port a Data Port. My OBD2 port is dead, will not connect to a code reader.
The SCI Data wires do not respond, they are fed by the PCM but testing of these wires say they are good from the port to the PCM.
The PCM is not sending information.
The O2 sensors have 2 white wires that are the heater for the O2 sensor on cold start. These white wires attach to the 5V feed from the PCM for power. These will show a ground when connected to the 5V feed if the 5V feed does not have power.
THIS threw me for quite a while trying to see why the circuit was grounded looking for dead wires. The problem in testing was I tested one at a time. The second O2 sensor heaters were on the same wires so I kept getting the same results until I dis connected both at the same time and the light came on. I had been chasing a non issue. Learning curve, time wasted.
The ASD ( auto shut down relay) is a simple relay but if it does not engage your engine will not run. The ASD is connected to 4 wires.
B1. Red White, main feed with key on 12V from 30A fuse in the PDC fuse #6. PDC is Power Distribution Center, should be named UnderHood fuse block. 30A is one of the large fuses
B2. #14 size wire Dark Green with pink stripe this wire is dead unless the ASD is active. It is 12V when engaged
B3. smaller 12 V feed from Fuse 12 in the glove box fuse box, gets power from the key switch, this is hot all the time if key is on and only powers the magnetic trip inside the Relay.
B4. is a dead pin, no wire attached
B5. #18 size wire Dark Blue Yellow stripe from the PCM/computer. This wire is a ground signal from the PCM. This is the Off/On wire for this Relay, if you wish to test the relay, turn your key on and touch this blue wire with a ground test lead. The relay will click on.
For B5 to turn on via computer signal the computer must see a good information feed from the Crankshaft Sensor, Camshaft Sensor and I believe the Fuel Pump is tied in somehow.
Note: as you turn on the key there is a 1.8 second time period where the ASD will activate, if it does not get the proper signal back from the Crankshaft and Camshaft sensor, Coil, A4 sensor ground, the ASD will turn off.
Another twist for you, if your ASD does not power up their are three fuses that don't power up also because they get power from the B2 pin on the ASD Relay, the Dark Green Wire with Pink Stripe, DK/PK
The #27 fuse and the #21 and #18 fuses in the underhood PDC Power Distribution Center will be dead. These are the fuses closest to the 4 relays. This also threw me, I checked my fuses right away to see if they were not blown and all were good, you need to also check to see if they are powered up with the key on. If not the ASD relay is not engaged.
Cheat Sheet for reading the wire diagrams and trying to make sense of them.
PCM this is your computer Power Control Module
PDC Power distribution center Under Hood Fuse block
Data Link Connector This is the OBD2 port under your dash where you plug in the scan tools
Fuse Block this is the fuse block behind your glove box in a TJ.
Other tips
all wires are noted in the schematics by size of wire IE: 14, 16, 18, 20 gauge.
It is noted if they are fused "F" or non fused "A" IE: F20
The color of each wire is also indicated IE: OR/G = orange with green stripe. The FSM has a page that shows each color if needed.
K - before the wire tells you it is a PCM interface wire
Z- before the wire tells you it is a PCM interface ground wire
V - wire goes to switches or solenoids
L - Lighting wire exterior
M- lighting wire interior
F- any fused wire, protected by a fuse
A - any wire unprotected by a fuse + battery wire
G - ground wire
E - dimming light circuit
D- data link wire OBD2 port wires
C- IE: C103 shows any connector, where wires can be disconnected
8W-90-1 shows all connectors and locations
S - Splice where wires are joined but continue as one after the splice
There is a Section in the FSM that shows all splices 8W-95-1
The PCM has 3 main connetors Don't disconnect or connect these with Key On you can damage the PCM.
C1 Black connector at the PCM
C2 White connector at the PCM
C3 Gray connector at the PCM
In my case the crank and cam sensors appear to be working fine but the signal to the computer is not turning the ASD on. Even when I engage the ASD by grounding the B5 ASD pin which supplies power to my dead circuits this jeep will not start.
After testing the wires to be sure they are good I have come to the conclusion my PCM/computer is dead.
I wrote this to help save the next poor soul from having to look up all this stuff. It takes forever to learn all the acronyms so I could start tracing the wires properly.
I knew nothing about a Jeep Wire system when this started. Now I know a lot I wish I did not have to learn. Hope it helps the next guy get fixed faster. I will follow up when I get a new PCM and test it.
I have concluded my headlight issue may be separate but the gauges not working is typical of the PCM failure.
My nephew had been driving this jeep before it failed and maybe he did not notice the headlight issue.
