I just picked up a 99 with LED headlamps and tails, Front markers and signals are not hooked up at all. PO doesn't have much info other than he was told the kit he bought would work with OEM flasher module.
I guess he has been using hand signals for a while now so it sounds like it never worked, Now it's my problem
Here's what worked when i got the Jeep:
Headlights
Tail lights
Brake lights
Back up lights
dash signal arrows
Here's what didn't when I got the Jeep
Tun signals cause the module to buzz
Hazards also buzzed
If I accidentally use the stalk it kills the brake lights for a while. The fuses are all OK
Tried a couple new flasher modules
Replaced the one under the dash when I got it with an OEM spec EP 26 from Autozone.
Hazards work - no signals at all
No Dash arrows
Tried the EP 36 with 3 prongs (no bad bulb circuit?)
Hazards work, no signals at all
No Dash arrows
Do I need to get the front stuff installed before any of this works? I'm in over my head a bit on this one no matter how many threads I read
The 726 one is what was in the dash when I got the Jeep
Headlights
Tail lights
Brake lights
Back up lights
dash signal arrows
Hazards also buzzed
No Dash arrows
No Dash arrows
