- Price
- 380
- Location
- Lanham, MD
For sale: 2.5" OME springs (front and rear), 4 procomp boxed lower control arms, and 2 rubiconexpress rear adjustable control arms.
Will also include a pair of metalcloak adjustable bump stops and a rear sway bar with sway bar extensions attached.
If you want them you can also have the 4 OME shocks and a spare set of stock front upper control arms.
The front lower control arms will need new bushings on the axle side and the shocks are probably at the end of their life. They function but have some dents on the rear and rock rash on all of them.
I'd recommend running 33" tires or smaller with these but I ran 35's with flat fenders.
$380obo. Trades/partial-trades will be considered. Things I'm in the market for are TJ full doors, tool boxes, work bench, bench vice, chain saw, bench grinder, pressure washer, sand blaster, weed wacker, air compressor 40-80gal, roof cargo storage box, tools...
OME front coils MPN# 2932 https://www.extremeterrain.com/old-man-emu-2-front-lift-light-load-coil-springs-9706-tj.html
OME rear coils MPN# 2941 https://www.extremeterrain.com/old-man-emu-25-rear-lift-light-load-coil-springs-9706-tj.html
ProComp boxed front lower control arms MPN# 55200 https://www.extremeterrain.com/pro-comp-boxed-front-lower-control-arms-9706-tj.html
ProComp boxed rear lower control arms MPN# 55400 https://www.extremeterrain.com/pro-comp-boxed-rear-lower-control-arms-9706-tj.html
Rubicon Express rear upper adjustable control arms MPN# RE3783 http://www.rubiconexpress.com/Suspension/Rubicon-Express-Control-Arm-Rear-Adjustable-Upper-Super-Flex-TJ-LJ-ZJ-Pair-RE3783.aspx?t_c=1&t_s=101&t_pt=3158&t_pn=R/ERE3783
Located in Lanham, MD
