Im buying the OME 2.5" lift, and a 1 inch transmission drop is required for it, if i add a 1" MML could i do without the transmission drop?
Some complain that poly body lifts get squashed and don’t give level lift, squeaking and eventually failing. The Savvy 1.25” aluminum avoids these pitfalls as does the Currie 1”. They’re really not expensive at $169.And does it really matter if a i go with a cheap BL or should i go with the better ones? Would RC be any good?
And what type of MML would you recommend? (i have a manual 6 speed)
You will more than likely not need a leaver extension. Ome should work perfectly with mml. The bl will help clear 33s. Check out @tomtaylz old build (white jeep). He had the ome ultimate kit and 33s.After research im probably going with currie MML and savvy 1.25 BL, and i would need a leaver extension for shifting right?
